SOURCE: no response to sylus taps
Hi Try This Squeezing the Axim gently in normal holding position Placing the Axim in the sync cradle (I have no clue why this works) Doing a soft reset Shutting it off and leaving it alone. Then Re-Starting it. The Axim, despite its size and weight, is not as rigid as it should be. If the case flexes far (or often?) enough, you'll get the "not responding to taps" issue. If you have the problem now,call Support, and get an exchange. Don't worry about getting a refurb. I use lots of refurb equipment, and they are no more or less likely to fail than new equipment. Note that if you continue to flex the refurb's case like your original (I carried mine around in my pants pocket), it will eventually develop the same problem.
SOURCE: iPAQ Not Charging from AC Outlet
If you are not using the original chargers it could be the type of charging cable. Not all cables that fit will charge the device correctly.
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
I have the same problem with my projection screen TV.
SOURCE: Hi, I have a plantronics CS60 that was working
Plantronics CS60: Hard Reset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink briefly to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect
