Question about Stihl Garden
Hi I'm having a problem with a STIHL TS 700 Saw . I'm not getting a spark . I have Put in a new ignition coil and it doesn't work . I've even Checked the Switch and it is good . I have even removed the wire from the Coil , and that doesn't even help me . Could you please tell me what is the Problem ?
    Loyalty:
    Visited the website for 30 consecutive days.
  • Stihl Expert
  • 358 Answers
You seem to have done everything, you need to make sure you have a 0.3mm gap between the coil and the flywheel magnets, you also need to give the starter a good pull when checking for a spark, if all this fails then the new unit is bad, is it a genuine Stihl part? if its a cheap Chinese copy then it will not be a good quality item.
Posted on Aug 26, 2019
6ya staff
SOURCE:
Moe
  • 335 Answers
SOURCE: no spark 350 chevy tbi
You need power on both sides of the coil with key on engine off. With test light on neg side of coil you should get flashing light with engine cranking. No flashing indicates no trigger from ign module. No flashing can also mean the pick-up is faulty. To check pick-up dissconnect from module and use analoge meter set on ohms.Check meter movement during crank. If o/k check rotor for burn through.and change module.
Posted on Apr 23, 2009
Anonymous
SOURCE: No Spark from coil
I have problem with coil not working. In the morning,car with not start, but if I run a wire from battery to (+) to coil (+) will start. the rest of day no problem,car will start. but next morning same problem no spark from coil. c
Posted on Jun 14, 2009
tombones
  • 3567 Answers
SOURCE: no sparking on a 1979 YZ 125
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Also check the wiring harness for loose and/or dirty connections. Look for bad plastic connecton blocks and abraided wires.
Posted on Jul 26, 2009
Anonymous
SOURCE: 1990 FORD F 150,SPARK ON THE COIL BUT NO FROM THE DISTRIBUTOR
i had the same problem. there is a group of wires that go by the distributer and branch off to the distributer and go towards the front. when i would jiggle it the van would die. it ended up being a pinched wire.
Posted on Aug 07, 2009
Anonymous
  • 21 Answers
SOURCE: 1991 Toyota Celica GTS 5A-FE. Engine runs great
Bad condenser in distributor,just cut the single wire going to it
Posted on Apr 21, 2010
Ts 400 stihl. No spark new coil fitted still no spark.
HAVE YOU GIVE UP THE serialNUMBER TO THE stihl agent AND THE YEAR OF BUILD of the saw ????
Because there can be in 1 year of build an modification on the ignition group .
Marketing technical modifications for use of different sparkplugs are sometimes happens on some Stihl models , but you should know that there is an adjustable little gap between the flywheel and the coil. and also the right sparkplug all is ask again your stihlagent where you ordered your coil now.
Aug 23, 2018 | Saws
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
I have the older model which has the 3 bolt ignition coil. If I replace the coil, does the new ignition coil have to be 3 bolt as well? the 3 bolt replacement coils are so much more expensive
Coils are usually engine specific, the number of bolts does not determine whether or not it will work. If you really want your chainsaw to work correctly - buy the right part. It's a cheaper than a new one! Using the model number you supplied, I found them for under $50, which is about the value of an old 050 Stihl -wow, that's a heavy old saw. If you are still (Stihl ;^ )) not sure, call a Stihl repair facility. There may be an old timer mechanic who knows.
Oct 19, 2015 | Stihl Ignition Module Coil 050, 051, 076,...
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 | Garden
Not getting spark when starting stihl ts 400cut off saw plug is wet.
fromsnor38@gmail.com HI GRYDERT your problem could be your on, off switch. This might sound funny, but switch the on off switch real fast several times, then see if you havee fire. If not check your spark plug. If you have a n
ew one try it. If that don't work check the connection at the plug to be sure it is makiong contact with the plug. If all this does't work you will have to go inside to the coil. They don't usually go ba d but it could. But first check to be sure it isn't grounded at the small wire from the switch. Good Luck.
Jun 07, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
TS 350 I have spark to the on/off switch, but no spark to the spark plug
The Short Circuit wires need to be looked at. Take off the cover over the flywheel. The two thin wires coming off of the coil need to be checked to see if there is a spot that has rubbed off and if there is a bare wire grounding out against the housing of the Cut Off Saw. May also check the coil wire going to the spark plug. This can also develop a spot that can ground out on the housing.
Sep 17, 2010 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl 410 wont start put new spark plug but no spark
Try a new coil.Hope this helps and Thank You for asking!!!
Jul 19, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Running bad with oil leaking out the muffler crimps. Too much oil in the mix? Cleaned the air filters already and checked the spark plug. Looks good, maybe the carb?
Check the spark arrestor screen and see if the screen has carbon deposits on it. If it does then you need to clean the spark arrestor screen and re install it in the muffler. You can clean it by burning off the carbon. The air filters on the TS 700 Cut Off Saw do not need to be cleaned, they only need to be replaced when the unit starts running poorly. The carburetor could have something in it that is keeping the needle from closing and flooding out the unit. I would suggest taking this unit to a Stihl dealer that has a Gold Certified Technician. You can use the dealer locator on the the Stihl USA website. I have included a link HERE. You can type in your zip code and it will tell you where the closest dealer is and what level of technician they have.
May 14, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
