Cooktops Logo
V
Virginia Conlin Posted on Aug 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn on glem64 electric cooktop
There isn't a "on" button (circle with stroke thru it) anywhere on the cooktop. Instruction manual keeps referring to it. Power on & checked.
Harrie
Level 3:
Top Expert:
  • Master 6,746 Answers
  • Posted on Nov 14, 2020
 Harrie
Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285762
Points
83153
Are you sure the cooktop is plugged in? Are you sure there is no blown fuse for that group?
What does error code L means on the delonghi cooktop
The L indicates that the child lock feature has been enabled. This ensures that the burners do not function while you clean the cook top and that a child can't turn on any burners.
The procedure depends on your cook top model. For some induction models, to toggle the child lock feature off, press the front right burner zone display and the booster function key (circle with a solid circle inside on the right of the selector zone) simultaneously. Then press the front right burner zone display again until the L disappears from the display.
See page 23 of the manual for the Delonghi DEIND804 available here: https://www.appliancesonline.com.au/public/manuals/Delonghi-DEIND804-Induction-Cooktop-User-Manual.pdf .
For an electric ceramic cooktop DTCH808, to turn off the child lock completely, press the bottom right + in a circle and the - in a circle (in the center surrounded by 4 of the + in a circle areas) simultaneously and then release the keys. Press the - in a circle again. See page 21 of the manual here: https://www.delonghi.com/Global/InstructionManuals/EN/EN-DTCH80B_im.pdf .
I hope this helps. Please add a comment with the model of your Delonghi cook top if these instructions do not apply to your cook top.
1helpful
Technik gas cooktop burner electric igniter never stops. Have to turn of electric at wall and lighter burners manually
Check if any button is pushed in in a weird way or if there's a lot of dirt around the buttons. Please clean around the buttons as far as possible.
The problem should be fixed then.
Jan 16, 2019 • Cooktops
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
My induction cooktop isn't working. When I push any of the touch pads, the numbers flash. There is no E for displayed, only the various numbers I push.
Call the co. And let them guide you thru this. Does your instruction manual give you any help. Hopefully, your board hasn't gone bad.
Whirlpool rc8920xrh cooktop
read you owner manual , and read any instruction. if does not have it
download from www.fitness.manualsonline. com and proceed according
God bless you
When using a burner and turning a knob the cooktop tripped a circuit breaker, how do I check what happened?
is this a common occurance or a one time thing? if it's common the cooktop might not be wired to the supply correctly causing th phases to be unbalanced drawing too much current from one phase instead of both evenly ish. you'd have to meter it out to see but if you aren't knowledgable with electrical stuff get an electrician to check it if it only happened the one time and isn't anymore probably don't need to worry about it
User Guide worktop make tecnik
I have a full Operating Instruction manual for the Tecnik 23 in. TKH4050 Electric Cooktop.
I would be happy to make a copy for anyone who needs a copy.
Please get in touch.
1helpful
How do I remove my electric cooktop...the conduit enter thru an L connector into the cooktop and prevents it from being lifted out...I cannot figure out how to get under the control knobs to access the...
On link below is a install manual It might not be yours but they are all pretty much the same. It will tell you how to install. You just do the reverse to remove.
Also you do not un wire the cooktop from the cooktop but from the junction box in the wall. Please make sure the breaker is turned off before you un-wire it.
http://www.jennair.com/assets/product/JEI0430ADS_Installation%20Instruction_EN.pdf
1helpful
Instruction manual or details please
I am sure there is one to download but did not found anything with google...
If search engines are no help, just ask some deep web specialists, e.g. http://manualfox.com - this is a manual search agency and if they don´t find it, it does not exist in the Internet.
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
