SOURCE: Error 99 in Canon EOS Rebel XS 1000d
Have you been to the support section of Canon's website to find out what "error 99" means?
SOURCE: Black line on back of paper printed by canon pixma
You will need a shop to dismantle the printer, the ink is being forced up onto the exit rollers from below. It needs a good cleaning plus a mylar shield installed to keep that from happening again.
SOURCE: Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
SOURCE: Panasonic DMC-TZ3: one day it's
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
SOURCE: My Sears 1/2 hp pn 41A4315-6D won't open using
Sounds like the receiver portion of your logic board has quit. The wall control is hardwired and doesn't use the receiver.
