This may give you the answer you are looking for. I am sure there is a procedure in the manual to change oil.
https://en.wikipedia.org/wiki/Dry_sump
SOURCE: engine oil problem
Whoa! Never remove the oil filter while the motor is running. Alot of vehicles have valve cover leakage and it is easily repaired with a new valve cover gasket. It is completely normal for the dipstick to be dry until the motor is off and all oil has drained from the upper compartments of the engine including the area where the oil lubricates the valve guides. Most mechanics will place the vehicle on a completely level area and then wait 15 minutes or so after the motor is off to check the oil. The dipstick will always show that you have low oil if you check it while the motor is running as the oil is elsewhere doing it's job. If you replace your valve cover gasket be sure to not overtighten and tighten in a random crisscross pattern so that you have uniform pressure all along the gasket. There are torque guides for this and you can usually get them from your local parts house. Buy a good torque wrench also.
SOURCE: 2008 yukon first oil change
THE OIL PAN IS GOING TO BE THE LARGEST PAN AT THE BOTTOM OF THE ENGINE. THERE WILL BE ONLY ONE PLUG ON IT. TO RESET THE OIL CHANGE REMINDER FOLLOW THESE STEPS. TURN THE KEY TO THE ON POSITION, BUT DO NOT START THE VEHICLE. WHILE THE KEY IS ON PUSH THE ACCELERATOR PEDAL ALL THE WAY TO THE FLOOR THREE TIMES. THIS WILL RESET THE OIL REMINDER.
SOURCE: oil going back from filter to sump in 1.7 astra after you stop it
add 1 quart of lucas oil it will cure it
SOURCE: 2012 Yamaha VX Cruiser Waverunner Oil Change HOW?
Should be a plug on the bottom off the cranck case.
SOURCE: what kind of oil for toyota land cruiser 2008
if your vehicle is diesel engine use SAE 15w40 engine oil.tks
