SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water
and/or solution sprays through the handheld tools, but not through the
main machine.
As others have suggested, I removed the water
reservoir, which exposes the 2 main water sprays mounted above the
rollers. Using, pliers, I carefully slid the clips back. Gently but
firmly removed the two red nozzles.
Elsewhere I have read
suggestions to just do one nozzle at a time. However, I found out that
if you remove both red nozzles, you can then blow through one side and
it will come out the other. In my case, that dislodged a nice
collection of crystal-like chunks (guessing it may be crystallized
residue from the cleaning solution).
There was also a bit of
blockage in one of the red nozzles, which I cleaned out. Make sure you
can blow through both of them with little resistance.
Reassemble:
Push red nozzles back into hoses. Using pliers, reposition sprung clip
back over the red nozzle. Snap nozzles back into place. Refill tanks
and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
SOURCE: Bissell proheat 2x carpet cleaner
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that will give you all the information you need to fix your Bissell
Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
teyet
SOURCE: The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
SOURCE: have a bissell powerwash proheat carpet cleaner
Go to the following site and enter the product name or model number:
http://www.bissell.com/user-guides/
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
