SOURCE: DOES PLASMA TV HAS 120HZ AUTO MOTION PLUS
This particular model has a 60Hz refresh rate. At this point there are no broadcasts or video sources outside of special labs that can generate enough data to produce a refresh rate of 120Hz. Expect this to become available in a year or so. Please realize that the human eye can not see changes faster than about 30 frames per second. The current standard refresh rate of 60Hz is twice that. The only change you could see (unlikely) would be a slightly smoother flow for fast moving scenes. Typical movement on the screen will not likely see a difference.
Dan
SOURCE: I have a new 40"
You didnt specify what type of samsung TV you have but the are picture presets for most of the ones i have come across, they are named in this format Dynamic, Cool, Smooth etc, they are presets so you can select the closest to the effect you want and then from there fine tune the picture with the brightness, contrast options, Hope this helps...
