Grilling Logo
Ernestine Johnson-Smith Posted on Aug 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i replace an ignition battery on brinkman grill 810-2513-s
Steve Pack
Level 3:
  • Master 7,128 Answers
  • Posted on Aug 23, 2019
Steve Pack
Master
Level 3:
Answers
7128
Questions
Helped
2276180
Points
27978
You don't, rep;ace the piezoelectric ignitor, it is the ignitor push button. Look online for a new one.
4 Related Answers
Anonymous
  • 63 Answers
  • Posted on Apr 05, 2009
SOURCE: Igniter problem
right in front where the red botton pushs in to light! grab the ring around that and un screw it!
bbmcdonald
B. McDonald
  • 14 Answers
  • Posted on May 30, 2010
SOURCE: instructions on how to put a brinkman gas grill
It might be best to just contact Brinkmann's Customer Service Department first. They should be able to either send you a Manual with snail mail OR point you to a link where you can download a copy of the instructions needed. Good Luck!
* The Brinkmann Corporation
Attn: Customer Service
4215 McEwen Road
Dallas, TX 75244
Toll Free:
(800) 468-5252
Local:
(972) 716-4262
OR you may send them an email through this link:
http://brinkmann.net/Customer%20Service/ContactUs.aspx
bbmcdonald
B. McDonald
  • 14 Answers
SOURCE: new brinkman gas grill---side burner lights on
I have a few ideas that might help.
1). Before going to the expanse of new parts, your igniter AA battery MAY need replacing.
2). Your igniter wires might be loose. Remove the battery and check junction box found behind the Control Panel and connect any loose wires.
3). Check that the end of each of your main burner tubes are properly located over the gas valve fitting.
4). There MAY be an obstruction over the main tubes not allowing the gas lines to access it properly.
5). If obstructions in the hose or regulatory assembly is suspected, it would be best to contact Brinkmann directly at 800-527-0717
Anonymous
  • 4736 Answers
  • Posted on Jul 05, 2011
SOURCE: brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
1helpful
3answers
Brinkmann 810-2511-S Grill. Is there an igniter battery on Brinkman grill model 810-2511-S and if so, where is the battery. Thanks
No it is Piezo Electric. No battery in the manual either. The battery operated ones have a button that you have to press to ignite and the battery a single AA hides under the button. Piezo make a big clunk when you turn the knob, but with a battery, it goes click, click, click.
https://www.manualslib.com/manual/951901/Brinkmann-810-2511-S.html?page=10#manual
Having said that, this page mentions a battery, but I think it is a mistake. Phone them up.
https://www.manualslib.com/manual/951901/Brinkmann-810-2511-S.html?page=17&term=battery&selected=2#manual
Here is my query.
https://www.google.com/search?q=brinkman+grill+model+810-2511-S+spark+igniter
Apr 27, 2023 • Grilling
I have a Brinkman BBQ.The igniter works and lights the main burner but when I turn on the second burner it wont ignite.I can light it manually so it clearly it is getting gas. What do I need to do?
Check the igniter with the gas off to make sure the secondary igniter is lighting if it has one. Otherwise reposition the igniter closer to the source. If it isn't flashing, if not, it needs replaced
Nov 16, 2016 • Grilling
Have brand new 810-3330-s brinkman grill main igniter is receiving no gas, is there a screw to adjust flame?
BEWARE: DO NOT TRY SUCH HAZARDOUS TRICKS YOURSELF AS LOCATING A SCREW TO ADJUST GAS PRESSURE. CONTACT THE DEALER OR AUTHORIZED CUSTOMER CARE.
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 • Garden
Looking for a brinkmann 810-3200G replacement burner
Unfortunately, your model grill has been discontinued by Brinkman. The burner you need, Part # 19810-3200-G is no longer available and there is no substitution.. Neither from Brinkman or other grill part sources. In fact, the only 2 parts available from Brinkman for you grill are an ignitor button & cooking grates.
I'm sorry, I wish I had better news for you. Thanks for choosing FixYa.
I need instruction on how to put together model 8300 proseries Brinkman
Click on this Brinkman link for the manual you need. Scroll down to the 6th Brinkman model listed to find your model and click on it. You can then download this adobe file and print it up on your computer for free.
http://www.brinkmann.net/Customer%20Service/OwnersList.aspx?category=Gas+Grills
Have fun assembling it!
May 15, 2010 • Grilling
No user instructions for brinkman smoker
May I get the make and model # to help you more
2answers
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 • Grilling
1helpful
Igniter problem
Top Grilling Experts
Paul Carew
john h
Are you a Grilling Expert? Answer questions, earn points and help others
