It will be a postal code
http://www.blaauwberg.net/postalcodes_results.php?value=f
SOURCE: Region Code
Try http://www.dvdexploder.com/how.htm
They have your modal listed...Costs around $10 for lifetime access.
SOURCE: Will a PS3 from Thailand work in South Africa?
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_5tgy6
SOURCE: How can I activate blackberry messenger on blackberry 9930 in south africa
You first need to buy R60 airtime for the network you are using such as MTN, Vodacom, Cell C etc. That R60 will be the amount you need for (BIS) Blackberry Internet Service. You need BIS to enable BBM (Blackberry Messenger) to work. Once you have topped up your airtime with R60, you need to dial *141*11# which should bring up the option to activate BIS. Choose BIS and not any other option. BIS is usually option 1, but just make sure you select to activate BIS. Once BIS is activated then you can go onto BBM (Blackberry Messenger) and you should be able to send messages. You then have internet access as well. The great thing about the BIS is that it lasts for a month, without you needing to pay anything after the R60 to send as many messages as you like for free on BBM, plus you can use the internet on your phone as much as you like too! I am experiencing a problem getting BIS on my Blackberry Curve which I shall ask a question about on this site!! Good luck :)
SOURCE: zip code for south africa
South Africa - Country code = +27
ZIP codes are a system of postal codes used by the United States Postal Service (USPS) since 1963. The term ZIP, an acronym for Zone Improvement Plan, was chosen to suggest that the mail travels more efficiently, and therefore more quickly (zipping along), when senders use the code in the postal address.
To call South Africa from the U.S., just follow these dialing instructions: First dial 011, the U.S. exit code. Next dial 27, the country code for South Africa. Then dial the 2-digit area code (see sample calling code list below) followed by the 7-digit phone number.
South Africa Telephone Code 27. South Africa telephone code 27 is used to make international calls from South Africa. You may also see 27 referred to as the South Africa country phone code, or South Africa international calling code.
