Https://www.manualslib.com/manual/1026433/Panasonic-Kx-Nt553.html
May need to contact phone office to obtain key.
SOURCE: cannot send pics as message
hey; my friend just send me the picture from message but everytime i click view; it doesnt work for me!; it said download fails @?
SOURCE: cant send picture message. need profile name.
You don't have any active MMS profile. You need to create it manually or you need to contact your service provider for MMS profile. Generally your mobile service provider give you free MMS profiles if you call them. You also need to check if you have MMS service activated on your mobile plan or not. You also need to check if you have working 3G/GPRS connection on your phone or not.
Summary: contact your mobile service provider for correct MMS settings for free.
SOURCE: I cannot change the message
It took me many hours to work it out!
- Menu.
- Settings.
- Phone settings.
- Phone profiles.
- Select (highlight) the one you want &.
- Select OPTIONS with the left soft key.
- Click Edit (1).
- Use the directional key (right) to highlight the New Messages.
- Scroll down to Message Alert.
- Left soft key OPTIONS & select edit (as above).
- Then click the directional key until you hit either Downloaded Music or sounds (depending on where you stored your sound file).
- Select your file.
- Left soft key & select SAVE.
- Then that's it, done!
Please email me with if it works for u or not. [email protected]
SOURCE: panasonic uf-7000 error message: change battery.
Remove the chrome scew on the side of the dark blue op panel and pull out the battery holder. The battery CR2032 is available everywhere
SOURCE: how would you record a
not enough detail - depends what voicemail system you have - stanadard one might be 200 3 1 1 or 500 3 1 1 (or even 200 5 1 1 or 500 5 1 1 )
