SOURCE: NEED A USER MANUAL FOR PANASONIC LUMIX DMC-FZ5
i'm not sure which one you have so here are both
DMC-FZ5K5.0 MP - 12X ZOOM
http://service.us.panasonic.com/OPERMANPDF/DMCFZ5PP.PDF
DMC-FZ5S5.0 MP - 12X ZOOM
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
SOURCE: My Lumix DMC-FS5 camera had locked memory card,
Move the slide switch on the side of the card.
SOURCE: Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you
could connect the camera video-out socket to a PC with graphics card
with video capture function. Some cards with video capture work with
skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
