Question about Cooktops
My Schott Ceran cooktop is flashing F, what do i do to resolve it?
6ya staff
SOURCE:
Anonymous
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
Posted on Nov 19, 2008
Anonymous
  • 317 Answers
SOURCE: Just bought a house and has a schott ceran cook
check the breakers in your electrical panel...its 220volts so there should be 2. if thats not it look under it in the cabinet thare may be a plug..thanks
Posted on Jan 03, 2010
simi902
  • 5 Answers
SOURCE: Hello I have a Miele Deluxe H818 oven
Hallo I have a Miele Deluxe H818 oven too.
I do not use my cooktop because I buy new with gas-metan.The original cooktop is only electrical.
Ivo
Posted on Dec 14, 2010
espressonist
espressonist
  • 1711 Answers
SOURCE: My schott ceran class top stove keeps saying F1 on
Here below we have aprocedure to try to see if you can save the ERC.
F1 touch pad / ERC test
This simple test will help determine
whether the ERC (Electronic Range Control or Clock) or the touch pad is
defective when F1 error code is present.
Note: Some models
incorporate the touch pad in to the ERC as a single assembly, in which case this
test is not necessary. Simply replace the ERC (Clock).
Warning: If
you feel in any way uncomfortable performing this test or making this repair,
please contact a qualified appliance repair technician.
1. Disconnect
power to the range (unplug the range power cord or turn the power off to the
range at the circuit breaker). It is very important that the power to the range
has been disconnected, so please double check before continuing.
2. Gain
access inside the control panel.
3. Disconnect the touch pad (also called
keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no
lose wires, or anything else that may cause a short when power is turned back
on. Assemble the control panel back the way it was.
5. Turn the power back
on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it
does not, replace the touch pad.
Posted on Dec 19, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: My miele induction schott ceran
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Posted on Apr 25, 2011
Educate me on buttons as i do not have manual for schott ceran cooktop model - 10109896
Google (schott)(10109896)(manual) without parens for button education.
Aug 01, 2018 | Cooktops
I KNEED NEW KNOBS FOR MY SCHOTT CERAN BLACK GLASS HOB
The reference to Schott, is the maker of the ceramic glass itself. The label outlining the manufacturer and model number will be located on the base of the cooktop. Once you obtain that, contact the distributor to obtain the required knobs.
Nov 14, 2016 | Cooktops
My Schott Ceran cooktop will only work on full heat and will not simmer at all. why?
usually there are 2 elements a smal and a large the small one possibly burnt out .
Apr 20, 2015 | Whirlpool 30" Schott Ceran Surface...
Schott ceran touch
might be transformer noise? try turning the cooktop circuit off at the electrical main switchboard.
or get your wife to stop singing opera!!
Oct 22, 2013 | Kuppersbusch Cooktops
Maytag schott ceran front eye wont get hot
I navigated the SCHOTT website to find a solution and was able to find out how to properly clean my SCHOTT stove top. I would check the Ceran FAQ list to see if your question is answered before anything else.
Nov 19, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
My miele induction schott ceran is being locked, and I can not open it to cook??
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Liquid spilled on cooktop Ceran schott
You will have to clean the control area connections .
Oct 09, 2017 | Cooktops
Diplomat schott ceran operating instructions
have lost the instructions on moving need to replace the instruction book for diplomatic schott ceran flat top
ritapollard1@hotmail.co.uk
rita pollard
8A LADIES MILE ROAD
BRIGHTON
SUSSEX
BN1 8QF
WILL PAY FOR POSTAGE
Jun 05, 2009 | Cooktops
Cooktops Logo
71 people viewed this question
Top Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
