Question about Sony Computers & Internet
Ticking sound with external Rode mic + sony ax53. Changes speed - like a leaky faucet. Def inside the circuit - not a mechanical sound from the environment. Not there with built-in mic. Suggestions?
  • Sony Master
  • 5,919 Answers
Might be motor-boating. Used to be a fairly common fault with older less sophisticated circuitry. The cause could be anything from a fault in an interim power supply to stray feedback causing an oscillation with a low speed harmonic. Considering your description it could be the latter - impedance mismatch maybe, between the external mic and the amp input...
Posted on Aug 20, 2019
6ya staff
SOURCE:
Anonymous
  • 16 Answers
SOURCE: Mic troubles
However, having said all that, the other problems you describe indicate a faulty mike.
Posted on Jan 19, 2006
anasmaq
Anas Al-Mustafa
  • 100 Answers
SOURCE: how to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
Posted on Jan 05, 2009
Anonymous
  • 520 Answers
SOURCE: how do i disable my built in microphone?
double click on the sound icon in sys tray to access properties and disable from there or just turn the slider all the way down
Posted on Jan 31, 2009
Anonymous
  • 300 Answers
SOURCE: GM 3.8L engine ticking noise after intake gasket change.
check where the thermostat housing is, there is a plastic cross over to the other side of the intake. The intake cracks right there. Loss of coolant will cause overheating, plus if you look behind the alt. or remove it and start the engine, you will see where it is leaking, that`s if it is leaking to the outside. Most times it does. If that is not the problem, then with a blown head gasket you will have white smoke out the exhaust all the time, and the coolant level will of course go down. If it is the intake gasket, then you will have coolant in the oil, easy to see when you check the oil, creamy brownish colour and of course you will lose coolant and it will overheat also. Most likely since you said `white smoke water coming out around front of intake ticking noise is usually lifter noise. your engine is fine.(to a point) try changing your oil put in a thicker oil to prevent metal to metal contact. go for a 15/40 20/50. let it run for a while(few miles), if it doesn't stop buy an additive called "engine lucas", that will dilute your oil just enough to allow it to lubricate your lifters. also when your oil level drops or your oil becomes dirty your lifters will make that ticking noise.(the one that increases with engine speed)
a blown head gasket 99% of the time will cause your car to smoke either blue or white.
Posted on Mar 20, 2009
Anonymous
SOURCE: DELL Inspiron 1525 laptop Built IN camera does not work
my camera in not workig after instaling webcam cd !!!!!11
Posted on Jan 23, 2010
Sony Handycam ux10/ux20. Why isn't it recording audio?
sir,
please use an external microphone and test, if there any corrosion or dust inside the mic jack, it will cause to dis recording of audio, use some cleaner liquid in the jack, still the problem persist, must open the unit and check the audio circuit with test equipment like oscilloscope.
Feb 01, 2016 | Sony Video Cameras
Leaky faucet
Need more info. Is it leaking in between the faucet and hose or the end of the faucet or around the handle of the faucet? If leaking between hose and faucet a little rubber washer will do the trick. If its the faucet it could be inside the faucet. You can buy a new one, or take it apart and take your parts to the local hardware store whom can assist you there. If its around the handle simply tighten screw ontop of handle.
Nov 11, 2012 | Washing Machines
I noticed today that my Rode mic didn't produce any sound at all. It has been on a mic stand for a couple of weeks at my home. I read that moisture can be one reason why the mic doesn't work. I...
The whole situation that you describe makes me believe that the Rode mic is ok. Please double check your cables, the connections and the settings at the mixer that you connect the Rode. Also make sure that the phantom power supply is enabled.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: https://www.fixya.com/users/technical114
Sep 10, 2011 | Rode NT1A Professional Microphone
I have followed the directions (the manuel and even youtube videos) about 5 times already, but I am not getting any reading from my mic. I have the US-144 and a mac. I talk into the mic, but it's not...
What model is your mic? Some mic's need the phantom power switch turned on. I have the US-144u and it works great with my RODE NT1-A both on MAC and PC. What software are you using to record with?
If you mic is not using the XLR type connection, you will have to set the switch to Guitar / Line In not Mic
Chris
Aug 10, 2011 | Tascam US-144 Sound Card
My Road NT 1A Microphone is not work In Sometimes. Mic cable is OK But Sound not to came in My Alesis Sound Card the Mic gain is Very hi level Coming sound in Sound Card but it is Very low level, But...
seems like u have a damaged capsule... the damage maybe caused by accumulated moisture or spit that must've got to the capsule... i have the same problem... if ur mic is still under the 10 yr warranty rode will repair it for free
Jan 16, 2011 | Rode NT1A Professional Microphone
Toshiba L310 LAPTOP.WHEN I CHAT WITH MY FRIENDS ON SKYPE THE IN BUILT MICROPHONE OF LAPTOP IS NOT WORKING PROPERLY,BUT WHEN I ADD EXTERNAL MIC IN IT IT WORKS OK.BUT COMPARE TO MY OTHER LAPTOP SONY, AUDIO...
Please try this out..
go to tools-->options-->sound Devices-->(UN) tick, Let Skype Adjust My Sound Settings.-->save
Reboot/Restart SKYPE i.e Log Out and Back in USING your password.
Feb 13, 2010 | Computers & Internet
Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Feb 12, 2009 | Rode (VIDEOMIC) Professional Microphone
Rode NT1-A Distortion on "S" sounds and plosives
This is typical component failure. The mic will require professional service. Condenser Microphone Mod Service
Nov 01, 2008 | Rode NT1A Professional Microphone
Rode NTK Power Supply and pins
I actually have a spare NTK power supply w/o mic cable or power cable that I can sell if anyone is interested.
Apr 05, 2008 | Audio Players & Recorders
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Open Questions:
Computers & Internet Logo
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
