Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
Posted on Sep 13, 2009
K3367 one pice toilet harmonic vibration
I have a Kohler 3367 one piece (low profile) toilet. The toilet began spraying water out of the seam between the lid and the one piece base. I bent the fill assembly slightly downward to move the spray from hitting the seam.
This has apparently created a loud harmonic vibration in the filler pipe with each flush. The harmonic vibration remians even after I moved the fill valve back to it's original position.
Any recommendations?
Anonymous
Level 1:
  • Contributor 49 Answers
  • Posted on Sep 20, 2009
Anonymous
Contributor
Level 1:
Answers
49
Questions
Helped
32756
Points
76
Check your water preasure. it sounds like it's to high and you should adjust your prv
How do you stop a kohler toilet from spraying water inside of tank lid
There should be a small hose that is spraying the water. That hose should be put inside the overflow tube and heald in place with a clip or put into a small hole on top of the tube. Only put the tube in just enough to hold it in place. If it is spraying from anywhere else you need to replace or repair the ballcock.
Water in bowl. water level almost below where bowl saris to widen! , Kohler cimmarron - Toilet tank is full, all water flushes out of tank when flushed it's been this way since we installed it
If I understand correctly, your water level inside the bowl is 3 or 4 inches from the top of toilet seat?
Sounds peculiar to have that water level since you would get splashing etc.
That is not sanitary, and would be a code violation.
Look at side profile of tank.
Look at porcelain behind bowl and you can see outline of "s trap."
This is the internal trap that each toilet has built in.
Purpose of trap is to a) set water level inside bowl and b) just like a sink trap, seal pipe from sewer air from entering home.
Photo shows trap on sample toilet, with line showing approximate level of water inside bowl.
Since photo is at an angle, the line appears to go downward instead of level. Again the line is approximation, and photo intended to show where you can look on your toilet.
Your tank should have similar s-trap feature. From the feature on your tank, you can see what level water is intended to be inside bowl.
Some more expensive tanks, outline of s-trap is not apparent.
If the water level is so high that you experience unsanitary conditions, this is a code violation, and toilet should be replaced.
Quick web search turned up Kohler contact page: http://www.us.kohler.com/general/contact.jsp
KOHLER Customer Care at
Phone: 1-800-4KOHLER (1-800-456-4537)
Hours: 8:00 AM - 5:00 PM (Central Time) Monday to Friday
You can refer Kohler to this link on Fixya so they can clearly understand issue.
CANNOT UNTIGHTEN EITHER TOILET SEAT SCREWS - SO TIGHT WILL STRIP WITH ANY MORE PRESSURE. STRAIGHT SLOT - . ON A LOW PROFILE KOHLER . THERE IS NOT ACCESS TO THE OTHER END OF SCREWS EVERYTHING IS...
screws can be accessed thru tank..take a hacksaw blade only n cut from above (careful not to scratch where can be seen)..nuts will fall in tank..will have to reach for them thru tank.
6helpful
I have the Kohler model 703 one piece toilet. It runs once about every ten minutes. It sounds just like a flush but nothing happens in the bowl. Any ideas?
Something is leaking. Your description sounds like tank water is slowly leaking and then the tank refills. You really need to use Kohler brand parts, as others pieces seem to not work well.
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
Plastic piece at top of tank spraying water after flushing all out of tank and everywhere! How do I repair or what can I do??
look at the bottom of the system there will be a small plastic U-bend about 1.5 inch long by about 1/2 inch widethat has dropped off silply insert it into the top of the system where the water is coming out of and push firmly.
3helpful
3answers
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
5helpful
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
3answers
Kohler one piece part number 1013282
Hi kayela,
I'm Harvey the Master Plumber.
Your question is: Just replace the fill valve for kohler one piece andthe fill valve sprays a stream of water out of the top and onto the undersideof the lid is that supposed to happen?
For some reason I can't seem to get the picture up. Nevertheless, the answer is no, it should not be leaking. Did you take a picture of the original before removal? Do you still have the original? Look carefully at the diference between the two. Make sure it's an exact duplicate and isn't missing parts. These one piece toilet parts are expensive but the suplier sometimes makes mistakes. You can only solve this problem if they match.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 • Home
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
