Question about Home Security
How do I open a M4 challenger safe? I have the keys but need to remove the golden plaque. Don't want to damage the safe by forcing it.
4 Suggested Answers
6ya staff
SOURCE:
Bill Boyd
  • 53755 Answers
SOURCE: got old honeywell safe No:HWF19004340, no key and don't know combination. Can it be opened?
contact a locksmith for the answer to your problem All safes can be opened by professional trades people.
Posted on Apr 06, 2013
maxcarson
max carson
  • 7627 Answers
SOURCE: Can't open challenger hotel safe. Any ideas?
Contact Maintenance. By the way I think you have the wrong category.
Posted on May 01, 2013
john h
  • 22486 Answers
SOURCE: Can anyone help me? I have electronic safe 28. Kingavon safe 28 is locked. I have No key. I want to get a key or how do i open without damaging safe? How do we get it open & whats cost?
notify a locksmith or try manufacturer for assistance
Posted on Jun 15, 2017
Testimonial: "i am unable to get manufacturers details online. So hard to find. My safe has no details either."
HI IN A CHALLENGER SAFE BOX I FORGOT THE PASSWORD AND I DONT HAVE THE KEY
Opening Challenger in wall Safe
Assuming you have a legitimate reason to open it without a password or a key, there is a video at the link above with a method.
Feb 03, 2018 | The Computers & Internet
I have a Namson SFT-25EA electronic safe, batteries dead, can't remember where I stored key, can I get into it and be able to re use or do I need to force my way in
A "Trouble key" has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
Feb 15, 2017 | The Home Security
Battery is removed and the keys are inside
Is it a safe with an electronic lock? The safe usually comes with a key that you should keep outside the safe not in it exactly for this flat battery scenario that you're in. The battery box for your electric lock is usually on the inside of the safe so you need the key to open the lock. You can force it open, check this video https://www.youtube.com/watch?v=aqC9V7SDKdQ
Jan 13, 2015 | Locks & Locksmithing
After installing my kozy world heater and lit the pilot the heater came on. all three plaques. this happened while the knob was still in the pilot position. the heater wont shut off.
I actually have three of these and what I found was the gas valve was stuck in the open position you may need to replace it or possibly remove it and try to clean it of any residue but be very careful if you don't know exactly what your doing then you need to get a pro. Remember that your dealing with propane and it could ignite and cause serious damage to you and your home. Please be very careful and you might want to call the manufacturer and talk to them about it. Because it is a gas appliance they have a responsibility to you if anything should happen then they may be liable.
Nov 25, 2014 | World Marketing Kozy World KWP196 3-Plaque...
My brother had a guy look at our Dell Inspiron N5010 laptop. and now they keyboard don't work how can i take the keyboard out?
you can't remove it easily if you are not an experienced personal. If you want remove it, pls remove the screws at the back side of the laptop. Before removing any part, you need to remove the battery from the laptop. After removing the screws, place the laptop to the wright position. Slowly up the keyboard from the top side. Pls don't force on laptop, it may damage your laptop...
Good Luck
Aug 03, 2011 | Computers & Internet
The minute and hour hands are "out of sync"... the
The problem that you describe--misalignment of the hour and minute hands--would be fixed in the way you'd describe--the watch movement would be removed from the case, and the hands would be removed from their pinions and placed down more accurately. This is a relatively minor repair if you have the right tools, but it's not something I recommend for the average DIY person.
The first challenge is removing the watch movement from the case. Some movements drop out easily, but others are kept in place by the crown and setting stem. These must be removed in a way that they can be re-inserted. Simply pulling them out by brute force usually damages the internal set lever; different movements have different mechanisms for releasing the stem.
The second challenge is removing the hands. Attempting to "slide" the hands on their pinions runs a high risk of damaging the pinions by making one or both of them oval instead of round. Very little force is applied to the pinions, so even a slight distortion can mean that your watch will start to hang up at odd times when friction is stronger than the force being put out by the watch movement. Even worse, it's possible to break one of these little parts--they're very strong, but they're also very brittle. A tool called, naturally enough, a "hand remover" is used to pull the hands straight up off their gears; they're then pushed back into their correct place.
For a qualified watchmaker or watch repair technician, this is a simple and inexpensive repair that should take them only a few minutes once they get around to actually paying attention to your watch. Given the high risk of damage to your watch if you haven't done this before and if you don't have a hand removal tool, I would suggest that you outsource this repair instead of attempting it yourself. I have ruined more than a few watches in the course of practicing this repair; it doesn't take much force to damage these delicate parts!
May 26, 2011 | Lucien Piccard 26024 Wrist Watch
Panasonic oven 4 dimensions inverter - The Genius We had it repaired about a year ago and today I noticed inside the microwave oven that there is a little plaque - that can be easily removed as it hold...
Yes I actually have the same model and mine has that very same plaque; screw included! Im assuming since mine has never been repaired and I purchased it myself from the store, that the plaque is safe by the companies standards.
Apr 29, 2011 | Ovens
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
How do I enter cheat codes for call of duty worl at war on playstation 3
Text excerpt found at: http://cheats.ign.com/ob2/068/902/902587.html Cheat: Cheat List Cheats are unlocked not by inserting passwords, but by acquiring the thirty Intel Pieces strewn throughout the game.
The more of them you collect, the more cheats you can access. On the left are the number of Intel Pieces collected, and on the right are the cheats that are unlocked, with an explanation of what each does.
  • 2 - "CoD Noir" Play the game in black and white.
  • 4 - "Photo-Negative" Game colors become inverted.
  • 6 - "Super Contrast" Game's contrast increases.
  • 8 - "Ragtime Warfare" The game feels like an old silent movie.
  • 10 - "Cluster Bombs" One frag grenade thrown equals five in explosion.
  • 15 - "A Bad Year" Enemies explode into tires when shot.
  • 20 - "Slow-Mo Ability" Game plays at 40% normal speed.
  • 30 - "Infinite Ammo" Just what it says.
Unlockable: Arcade Mode To unlock Arcade Mode, beat the game once through on any difficulty level. Arcade Mode itself is split into two options - Full Challenge or Level Challenge - that add extra replayability to the game.
Unlockable: Prestige Mode To unlock Prestige Mode, which is a multiplayer-only mode, you must reach experience level fifty-five. Instead of capping out at level fifty-five, which is the highest level, Prestige Mode allows you to start again from level one. This can be done a total of ten times, giving you ten different icons in in-game lobbies to show your extreme achievement.
Unlockable: New Mission To play an all-new mission, which is an extra mission after the main quest is completed, beat the game and view the ending credits thereafter. After they've run their course, you will then be given the opportunity to play one last single player mission before all is said and done.
Unlockable: Golden Weapons To unlock the following "Golden" weapons, fulfill the requirement listed.
  • AK-47 - Complete all Assault Rifle challenges
  • Desert Eagle - Attain Level 55
  • Dragonuv - Complete all Sniper Rifle challenges
  • M1014 - Complete all Shotgun challenges
  • M60 - Complete all LMG challenges
  • Mini-Uzi - Complete all SMG challenges
Unlockable: Multiplayer Weapons To unlock the following weapons in multiplayer mode, reach the numbered rank listed.
  • Assault Rifle (G3) - Rank 25
  • Assault Rifle (G36C) - Rank 37
  • Assault Rifle (M14) - Rank 46
  • Assault Rifle (M4) - Rank 10
  • Assault Rifle (MP44) - Rank 52
  • LMG (M60E4) - Rank 19
  • Pistol (Desert Eagle) - Rank 43
  • Pistol (Golden Desert Eagle) - Rank 55
  • Pistol (M1911) - Rank 16
  • Shotgun (M1014) - Rank 31
  • SMG (AK-74U) - Rank 28
  • SMG (Mini Uzi) - Rank 13
  • SMG (P90) - Rank 40
  • Sniper Rifle (Barret) - Rank 49
  • Sniper Rifle (Dragunov) - Rank 22
  • Sniper Rifle (M40) - Rank 04
  • Sniper Rifle (R700) - Rank 34
Hint: Intel Pieces Below is the level distribution list for Intel Pieces, which are enemy laptops full of information strewn throughout the game. There are thirty of them total. The left column is the level in question, while the right column is how many Intel Pieces can be found on that level. Levels with no Intel Pieces are excluded completely.
  • Level 2 - 2
  • Level 4 - 2
  • Level 5 - 3
  • Level 6 - 2
  • Level 7 - 2
  • Level 9 - 3
  • Level 10 - 2
  • Level 12 - 2
  • Level 13 - 3
  • Level 14 - 2
  • Level 16 - 2
  • Level 17 - 1
  • Level 18 - 2
  • Level 19 - 2
If the information was helpful to you, please give me a rating.
Thanks.
OpenSource13
Apr 18, 2009 | Sony PlayStation® 3 (60 GB) Console
Home Security Logo
Top Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
