My d2360 printer prints ok when im using all text print but when printing pictures, it has 4 line gap and when printing full pages it has multiple 4 line gap with the same distance and it seems to be the paper roller is my problem. how can i fix roller of my printer?
I have aligned the cartridges, cleaned the cartridges, but portions of lines of text are not printing like something is stuck on roller and blocking text from printing onto the paper.I have aligned the cartridges, cleaned the cartridges, but portions of lines of text are not printing like something is stuck on roller and blocking text from printing onto the paper.
AnonymousMar 26, 2014
Why i my printer printing color horizontal lines on my paper?Why i my printer printing color horizontal lines on my paper?
You can't post conmments that contain an email address.
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Didyourefillthecartridges?Ifyes,youseemtomuchinkrefill.Whenhprefilledcartridges,respiratoryholesmustbeclosedasusual.The holeshould not besealedbutshould notbe tooloose.Iftootight,the inkwillnotcome out,iftooloose,inkwillfloodbecause theforceof gravity.At the time of printing,and emerginggaps,try toheadoffand checkthe bottom of theheadisthe inkfloods.
1.Press
Setup
2.Select
Maintenance and press OK
3.Select
Nozzle Check and press OK
4.Press
Start
5.Check
the nozzle check pattern that prints to see if there are gaps in the lines
6.If
there are no gaps, the print head is clean and you can continue printing If
there are gaps or the pattern is faint, clean the print head
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white." 2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab. 2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer. 2. Get a damp paper towel. 3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 5. Next dab the cartridge on the towel to make sure that the ink is flowing. 6. Snap the cartridge back into the printer. 7. On your computer, select "Old Cartridge installed." 8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
The problem you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge. You can fix this problem with one of 2 ways.
Please select the "Black" only option following the steps given below:
1. Click on "Start," "Control Panel" and click on "Printers and Faxes."
2. Right click on the "Lexmark printer icon" and select "Properties."
3. Select "Printing Preferences," click on the "Quality/Copies" tab and choose "Print Color images in Black and White."
4. Select "OK."
You can also change the color of your text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink please try the following:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Follow these steps to clean the print head using the control panel on the printer:
1. On the Main Menu, press UP or DOWN arrow to highlight More Options, then press OK.
2. Press UP or DOWN arrow to highlight Maintenance, then press OK.
3. Press UP or DOWN arrow to highlight Clean Print Head, then press OK.
4. Press OK to begin cleaning the print head.
*NOTE: The cleaning takes several seconds, during which the message 'Cleaning print head. Please wait.' appears on the screen.
5. When cleaning is complete, you see a message asking if you want to print a nozzle check pattern. To see if the nozzles are clean, load a sheet of photo paper, then press OK to print the nozzle check.
6. Check the pattern to see if there are any gaps in the lines. If there are gaps, press OK to clean the print head again. If there are no gaps, press Cancel to go back to the PictureMate Main Menu.
