Question about Toro Garden
I need step by step guidance with the toro Ddc 4.
How to accurately read the oil dip stick on a Toro mower?There is never a clear line of oil on the stick which has two holes as markers.
Did you ever consider checking manual for guidance? It is very clear regarding correct fluid level. Read it.
Aug 28, 2017 | Toro Garden
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
How do I remove the blade of my SR4
This is from the Toro owners manual for SR4 euper recycler model 20058 serial number 250003464
The steps and picture are on page 18 of the manual 3352-864[1].pdf
You can enter those numbers on this page for a manual:
https://lookup3.toro.com/request/request.cfm
1. Disconnect the spark plug wire from the spark
plug. Refer to Preparing for Maintenance
2. Tip the mower onto its side with the air filter up.
3. Remove the
2 blade nuts (A)
and the
stiffener (B).
4. Remove the
blade (C).
5. Install the blade and the stiffener that you
removed in steps 3 and 4.
6. Install the blade bolts and torque them to 15 to
27 ft-lb (20 to 37 N?m).
The replacement blade part number is:
108-3762-03 (google / net search)
Thanks for choosing FixYa,
Kelly
May 20, 2011 | Toro Power Lawn Mower
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Aug 03, 2010 | SAMTRON 55V 15" CRT Monitor
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
KVM is Starview SV411. I'm Testing Windows 7. The problem occurs with all versions of Windows 7 but does not occur with previous versions of Windows nor with Linux. I set the display to 1680x1050 on...
The KVM switch you have did not support "Active Full-time DDC" which Windows 7 need to keep communicating with all connected systems over the KVM switch. Two solutions: find a DDC Ghost adapter put in between the KVM switch and connected Win 7 system. Or just replace a new KVM switch which support Full-time Active DDC function - such as ConnectPRO new PR or UR serial KVM switches.
May 05, 2009 | StarTech.com StarView SV411 4-port KVM...
Need wiring diagram due to toro wheelhorse 212-5 12hp not startin
Go to www.toro.com then customer care, then manuals & parts, type in model no. and see if you can find wiring diagram in the manuals.
Mar 30, 2009 | Toro Lawn Mower With Toro Power Tools
Vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 16, 2008 | Samsung SyncMaster 750S Monitor
Garden Logo
46 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
