Question about Cameras
My charge 3 quit working yesterday. took off to wipe off and put back on will not work. fully charged.
6ya staff
SOURCE:
Anonymous
  • 2985 Answers
SOURCE: my nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Posted on Aug 05, 2007
Anonymous
SOURCE: Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Posted on Nov 09, 2007
Anonymous
  • 132 Answers
SOURCE: Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Posted on Nov 16, 2008
dr1plain
  • 24 Answers
SOURCE: fully charged battery. no response when key is turned to start
I like to start by making sure the starter gear not locked into the flywheel , this happens a lot on briggs take your hand turn the flywheel screen counter clock wise it will walk the gear down , you should be able to turn eng by hand now if not gas leaked into eng .
or eng is locked up.
Next I like to jump the starter solenoid to find it follow the heavy red wire from the battery it will led to it, there are 2 kinds 4 post and 3 post looks like you have 4 to test a 4 post unplug both small wires from the spades , you will need to small pices of wire hook one small wire to spade and ground it to frame of tractor now take the other wire hook it to the other spade and touch it to large stud that leads to the battery make sure you have parking brake set it may crank over, this by passes all safety switches and starter switch if it cranks over battrey good starters good solenoid is good .
safty switch on clutch pedal of mower deck engage switch not seat switch .
IF it does not crank over use a heavy wire or pliers jump large stud to large stud if cranks over solenoid is bad .
Posted on Feb 08, 2009
Patrick de Man
SOURCE: i can't get the charging light to turn on.
I have the same problem, after our building had a electricity problem. The electricity spiked when the utility company came to fix a problem. Several adapters in our apartment seem to be affected. Like my Kone, my dirt devil detailer had the same problem: charging light didn't come on, and while it charges, it only gets up to weak power. I got a new charger/adapter and when I plugged it into the base, the charging light was working again.
Posted on Jul 18, 2009
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My huawei ascend m860 wont charge. when i plug in the charger nothing happens. it was working fine yesterday and last night it wouldnt charge up. today i bought a new phone charger and it still wouldnt...
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Dec 31, 2010 | Cell Phones
Quit working, won't take a charge
GET IN TOUCH with NINTENDO customer service , they would be happy to help you out , heres their SUPPORT WEBSITE http://www.nintendo.com/consumer/systems/dsi/en_na/trouble_home.jsp
or call 1-800-255-3700 , hope this helps , thanks AJ
Oct 23, 2009 | Nintendo DS Lite
New Chocolate 3, charged fully; won't turn on
This may mean that this is a hardware malfunction, and that it should be taken back to the place from where it was purchased for either repairs, or refund.
Some possible solutions: Take the battery out, and put it back in, then try turning to cell back on.
Call the support line for the company that sells this phone, in this case, it is LG.
Jul 21, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Battery won't charge
a car battery? how eactly do you do that?
May 22, 2009 | HP Hewlett Packard Pavilion DV9500T 17"...
Charged for approx. 6 hours then wouldn't work
I copied this from the Philips website... this took me FOREVER to find! Their site isn't the easiest to find products on...
"Insert the small plug into the shaver and put the powerplug in the wall socket. When you charge the appliance for the first time or after a long period of disuse, let the shaver charge for at least 16 hours. Remove the powerplug from the socket and the small plug from the shaver as soon as the batteries have been fully charged. Ignore the charge indicator when you charge the batteries for the first time. The batteries are completely new and need to be charged longer than the time indicated by the charge indicator to ensure that the back-up capacity is fully charged as well."
I hope this helps. Please remember to rate my help! I would greatly appreciate it!
Apr 26, 2009 | Philips Philishave Cool Skin HQ6760/HQ...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Nov 06, 2007 | Vtech IP8100-2 Twin Cordless Phone
My nikon d70 won't turn on and the battery if fully charged
Aug 05, 2007 | Nikon D70s Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
