Lands Phones Logo
sonia snowling Posted on Aug 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Handset wont turn on - Lands Phones
Ron Rak
Level 2:
Habit-Forming:
  • Expert 138 Answers
  • Posted on Sep 13, 2019
Ron Rak
Expert
Level 2:
Habit-Forming:
Answers
138
Questions
Helped
134948
Points
294
How is the battery?
Security alarm wont turn on
Check your batteries in the handset, make sure that all the doors, boot and bonnet are shut. Now try. .. still no go then maybe try this
There is a button hidden under the dash somewhere usually on the drivers side, put your key in and turn on the ignition then hold down the button under the dash till the alarm sounds. Turn off the alarm via the handset, or push and hold the button again. You may need to open and close the door. Lock and unlock then try again.
My 6300 wont switch on. {battery is charged} iv used a replacement none nokia battery,it was working ok. it wont charge either
Hii
Firstly never try to use local battery because they are not good enough and damages handset .
check your battery in other mobile if its works in other mobile then your handset need to be FLASHING ie. updation is required.
Update your handset and never use local battery always use nokia brand.
Thanks to help you
8helpful
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Phone wont turn on it just blinks red
just connect your handset using datacable to your pc or laptop and then install desktop maanager and take a backup of your handset and reinstall your operating system.
1helpful
My LCD wont turn on
Might possibly be a software issue. Why dont you try visiting the nearby service point, or if your handset is still under warranty, contact the manufacturer, They will definitely be of help.
Hope this helps !!!
1helpful
Second phone not working.
From the manual:
VERY IMPORTANT: BOTH HANDSETS MUST BE REGISTERED TO THE
MAIN BASE BEFORE USE. After the 2nd handset has charged for 16
hours, place it on the main base station for 20 seconds, it will then
automatically register and verify its security code.
Phone 6233
try to change the battery in ur handset dear otherwise try with a diffrent charger, or if still the problem presists than reinstall the software.
14helpful
4answers
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
