Coffee Makers & Espresso Machines Logo
Juanita Wilson Posted on Aug 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn auto timer off of my kitchen aid coffee maker KCM111
teinesamoa
Level 2:
Habit-Forming:
  • Expert 39 Answers
  • Posted on Aug 25, 2019
teinesamoa
Expert
Level 2:
Habit-Forming:
Answers
39
Questions
0
Helped
22108
Points
131
Here is 2 solutions, hopefully this works
Solution A
There is a 2 hour timer on the machine so it automatically shuts off after 2 hours. However...should you wish to turn it off sooner you can just hit the On\Off button. Or...you can always unplug it...but then you have to set the time again when plugged back in.
Solution B
I am including 2 pics I've circled what I think will help resolve your question and a link for the manual.
https://www.kitchenaid.com.au/sites/default/files/5AKCM223CU.pdf
How to turn auto timer off of my kitchen aid coffe - 2019-08-24 (10)_li-0pneetlr0b5gslly3nzfgy2g-4-2.jpg
5 Related Answers
A
Anonymous
  • Posted on Apr 03, 2008
SOURCE: I have a Kitchen Aid
oven temperature not hot enough on bake
Anonymous
  • 379 Answers
  • Posted on Dec 27, 2008
SOURCE: I dont have a manual
http://www.kitchenaid.com/custserv/service.jsp
best i can do is give you link to kitchenaid support , type in your model number on that page and download the manual , since we don't know your model number , if you need more help please give model number .
Anonymous
  • 10515 Answers
  • Posted on Mar 25, 2009
SOURCE: Error Message
Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting! Also, use a spell-checker before improving this posting.
To clean hard water deposits from a coffee maker use distilled white vinager. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinager and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
Thanks.
Anonymous
  • 145 Answers
  • Posted on Jul 08, 2009
SOURCE: Kitchen Aid coffee maker err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears. This may take a few seconds.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Anonymous
  • 34 Answers
  • Posted on Feb 01, 2010
SOURCE: coffee maker wont turn on
maybe you bought a false one.
try bringing it to a specialist, to a technician. or bring it where you bought it.
or maybe you a new one.
try this link. hope it will help you with your concern.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Clean keeps flashing even when I've cleaned
External visual cleaning is not enough.
The coffee maker needs internal cleaning.
Please descale the machine to remove the error message.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
I set up our new coffee maker and it didn't grind...ordered it online from Macy's but had no manual and didn't know what to do...put coffee grinds in the top and then set up the timer for this...
You need to swivel the brew basket cover until it locks for the coffee to grind. Then turn the machine on and the coffe will grind. , then turn the machine off, add water and press the auto on to use the auto timer.
2answers
Coffee maker wont turn on its a kitchen aid pro line
Check your gfci plug/breakers. If its not the breaker there is a thermo resistor inside the coffee maker. You can find them at your local Radio Shack.
TIME AND TIMER PROBLEMs
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KCM511&siteCd=KAD
If not that model, you should be able to navigate to your particular model. =>
Good Luck!
2answers
I dont have a manual for my Kitchen Aid Coffee makers. Im not sure how to set the time and how to set an auto timer to go off. Help?
If it's KCM511, follow this link =>
Good Luck!
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
