SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
SOURCE: whirlpool dryer wont start
hello theres a long pin that sits inside the door make sure it has not snaped off if thats ok then the trouble may be caused by the capacitor next to the motor white cyilnder with couple of wires coming off
regards
shaun
SOURCE: Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
SOURCE: the blue is oval shape drawn upward on the bottom
YOU HAVE CONVERGENCE PROBLEM. you need to have an electronic technition replace convergence ics and related resistors and pico fuse. J.D.W.
Testimonial: "I REPLACED THE IC'S IT WORKS FINE. THANKS"
