I hope this helps you get it up and running... https://www.manualslib.com/manual/738672/Kenmore-970-3364-Series.html?page=1#manual
Testimonial: "This did not help me. I would like to know if you can send me a manual on my model # 970-336492, from this I can see all what I am suppose to do. Please let me know if you can send me a Manual?.Thank-You"
Gas stoves are easy, but can be dangerous to try and fix for yourself. If you go to Googles a search on your make and model, you may end up at getting the manual. Sears closed down its stores, and they may have a web site where you can find the manual. Kenmore is a Sears brand, but the stove is made by one of many companies that made appliances for Sears, so careful web searching may help you. I did find your manual by using Google on a simple search, it was the first thing to come up. It looks like you are in Canada by the place i found the manual. Fixya did not let me attach the PDF, but you can see the image I attached of the web search I did. It shows what the manual will look like when you find the link to download it.
SOURCE: kenmore elite gas stove
f-1 means the ERC is bad. sometimes turning the breaker off for a couple of min will help but if not the the clock/oven control needs to be replaced
SOURCE: Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
SOURCE: kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
SOURCE: kenmore gas stove makes a buzzing sound
Is the door locked?? Is it an electronic buzzer sound??
hold the CLEAR button for 3 seconds - the door will unlock.
open the door - and press CLEAR for 3 seconds.
Error code may come up.... close and re-open the door.
Are there any indications on the display?
Or is this a mechanical buzzing from underneath? in this case your gas regulator's diaphragm has failed.
If the above reset doesnt wokr (and the sound is electric) your circuit board will need replacement.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Specifically which manual do you need? The link I provided is for your model. The 970-3364 range has two variants, the 336482 (white) and the 336492 (black). The only other manual I have found for this is a technical service manual detailing parts.
The link I sent was for an electronic version which could be printed out on a computer with PDF reading software,
