Ovens Logo
Gail Mitchell Posted on Aug 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I would like to know how to go about using the self cleaning oven controls on my Kenmore gas stove, I never got the manual with it. Could you send me a manual I have the model number #970-336492.
MatchstalkMan
Level 2:
Sergeant:
  • Expert 261 Answers
  • Posted on Aug 18, 2019
MatchstalkMan
Expert
Level 2:
Sergeant:
Answers
261
Questions
0
Helped
68698
Points
868
You should be able to find the information you need in this manual... https://www.manualslib.com/manual/738672/Kenmore-970-3364-Series.html?page=1#manual
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Oct 11, 2008
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Anonymous
  • Posted on Dec 09, 2008
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Anonymous
  • 8197 Answers
  • Posted on Dec 18, 2008
SOURCE: I have locked my Kenmore self cleaning stove, now it won't open
Sorry you gave the sereial # for the oven. Need model #. Here is an manual that might work for you. cout and past in address bar.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Or you can go to this web sight and look up your oven.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q106688
Good Luck
Anonymous
  • 6784 Answers
  • Posted on Apr 16, 2009
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Anonymous
  • Posted on Aug 27, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
1helpful
My KitchenAid Supra double oven shut down completely while in self cleaning mode. Control panel is completely blank & oven door is locked
when you put it into self clean the oven gets up to 1000 degrees and it will damage the electronics in the oven and it sounds like this happened to you,i've been telling everyone i know not to do this until after the holidays in case something like this happens you won't have a stove for the holidays and also i tell them to never use the self clean use easy off works just as good,sorry to hear about you stove,if this is an older stove most likely you won't be able to even get a new clock assy. but you can send your old clock assy. out to get rebuilt to
http://generaltimerepairs.com/
you either do this yourself or get someone to remove the old clock assy. make a wire diagram,send the clock assy. out to have it rebuilt they send it back to you and you reinstall it and don't use the self clean again.one more thing i think there's a thermal fuse in the ka and that could have popped,you have to check it with a meter hope this helps and good luck.
Directions on gas self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 24, 2010 • Ovens
HOW TO USE THE SELF CLEAN FUNCTION ON A KENMORE FREE STANDING GAS STOVE
heatman101
2answers
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 • Ovens
Good Luck
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
142helpful
10answers
Self cleaning oven directions
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
