We see what appears to be the inlet but it is just open into the transom so the hose must have been removed. Unable to find any kind of manual or boat schematic to help us out.
SOURCE: LG WM-2277HW Front Load Washer E1 error
You may have a bad valve. The multi valve is cold and the single is hot. You can go into test mode and check them out to see if how the are fuctioning. Caution must be used. DO NOT GO INTO TO TEST MODE WITH CLOTHES IN UNIT AS IT WILL NOT BALANCE OUT FIRST AND WILL BOUNCE ALL OVER, AGAIN DO NOT DO THIS.
here is how to acces the test mode
With the unit off
Press and hold 'spin speed' and 'soil level'
turn the power on
press the start button to advance
once the tub will rotate clockwise
2nd time low spin speed
3rd high spin
4th inlet valve prewash
5th inlet main wash
6th hot water
7th bleach
8th tumble counter clockwise
9 heater comes on for 3 seconds
10 circulation pump
11 drain
12 power off
again do not attempt this with clothes in the unit.
if the valves don't activate fully than it is a bad valve and it has to be replaced.
Sgt 48
SOURCE: fuel hose routing
I would expect the hose to go:
fuel tank -> primer pump -> carburettor -> (overflow) fuel tank.
Good luck, they tend to be very fiddly.
SOURCE: cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you
have nuisance water leaks around the base of your dishwasher, you may be using
a detergent that is causing too much suds. Cut back on the amount of detergent
you use, and see if that makes a difference.
Water that spills through the door
vent is usually caused by improperly loading dishes. Leaks from the door itself
may be caused by a faulty door gasket or door tightness adjustment. you should
check the main tub seal, the door latch, the door gasket, the water-inlet valve,
and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet
up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose
connection. Remove the lower front panel, and check the hoses. The pump seal
may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If
this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
SOURCE: I have a kenmore elite H3 washer. The cold water
Check the inlet valve solenoid wires for resistance with an ohms meter. The cold and hot solenoids should have close to the same resistance. My washer had a weak solenoid causing the hot water valve to close after 4 or 5 seconds. While checking the solenoid wires for resistance with the ohms meter, I noticed the cold side had 51 ohms but the hot side only 8 ohms. Hope this helps.
