SOURCE: Using Intellisense without remote
some of the universal remotes by phillips have but not all have the program inside the remote for it u have to look on the box u can allso call magnavox witch is the same thing and ask customer service if the have a universal remote that will do that for u i hope this hp some
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
SOURCE: How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings
via the MAIN MENU screen when you press both CH UP (8) and
DOWN (9) on the TV set.
• Some features of your TV Set will not be accessible without the Remote
Control. If you lost your Remote Control, contact a Sharp Authorized
Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
SOURCE: am i able to get into the menu of small orion tv without a remote
Try holding down both volume buttons on the front of the set. If the menu comes up use the the volume and channel buttons on the front of the set to navigate in the menu. I hope this helps you.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
