It sounds like you may have mineral buildup in the system. You can try filling the water tank 2/3 with water and then filling it with white vinegar. Steam until the tank is empty. This should clean the buildup out of the machine.
By the way, Rather than just running the vinegar/water out, this solution is good for bathrooms, kitchens, sinks, showers, and windows.
SOURCE: can you disperse a water and vinegar mixture with
If you do this the vinegar will likely disperse hard water scale as it cleans the inside of the element. While it shouldn't stain anything it will likely cause sputtering as it breaks down the scale. If your goal is to clean and disinfect a surface that is vinegar friendly, I would consider taking the extra step of spraying the surface with a spray bottle with the vinegar. Bleach in steam might puff back at you in a cloud and burn your eyes and skin so be VERY cautious on the bleach.
SOURCE: How much water do I add to the steam buggy
I measured it for you, from my cup.
It's 18 Fl ozs or 500 ml (1/2 litre)
Anybody know where I can buy a spare nozzle.
SOURCE: How many PSI's does steam buggy have and also what
Don't know about the PSI but the temp can be in excess of 200F
Testimonial: "very helpfu"
SOURCE: STEAM BUGGY INSTRUCTIONS
its been awhile since I've used the steam buggy and when I went to use it -it put out a little steam and them quit. what can I do.
SOURCE: STEAM BUGGY PARTS
Hi, try to purchase on amazon Chemical Free Whole Home Steam Cleaners. If can't find exact part, you can contact sellers (probably someone can provide parts) Hope this was helpful.
