Give this site a try:
https://cheaptoilettanklids.com/store/?gclid=EAIaIQobChMIm9y29Y6I5AIVRSaGCh2n_A7dEAAYASAAEgKol_D_BwE
SOURCE: 1995 Ford Escort fuek tank
Yes, a metal tank can replace the plastic one provided it is designed for the same year, make and model vehicle. You shouldn't have any problems with a replacement tank.
SOURCE: Replacement of gas tank on a Sears GT3000 riding mower
if theres no leak yet you can easily patch it with an epoxy puddy, available at your local auto parts store. i've used it myself on gas tanks, radiators, boats and its never failed me yet
SOURCE: toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
SOURCE: Vitra elongated Toilet
Sounds like you need to replace the fill valve assembly. It is not expensive or difficult, just a little messy
SOURCE: Where can I buy a replacement water tank? I
No problem, Here it is...
http://iwantsweetdeals.com/Keurig-B40-B60-Water-Reservoir-Tank--P1207341.aspx
