SOURCE: where to buy CRT TV Philips tube ?
Picture tube will not cause NO color problem, color circuitry problem.
SOURCE: Manual for Philips 32'' crt model: PW9617/79
I was able to find a link to download your service manual.
Here it is. You will have to choose the language then it should download for you. You can save it as a PDF.
http://www.nodevice.com/user_manual/philips/tv_widescreen/32pw961712/download.html
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to provide a FixYa.
SOURCE: how to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
SOURCE: philips tv model 21 pt 5007/69 circuit manuel
my tv control panel is locked.there is only on screen av1.it is not changed.
SOURCE: I have a Philips CRT
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers as required. Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge. I
hope this helps.
