Https://www.lowrance.com/en-au/help--support/fishreveal-software-upgrade/
It wont hurt to update any software,
Hope it works out,
cheers.
SOURCE: Can a HDS 5 Lowrance
Hi, well I am sorry to be the bearer of bad news but those two are NOT interchangeable sorry. The "Drive Current & Voltage" for the Transducer are not the same at all, in fact i don't even think that the "pin outs" are the same? but cannot remember off hand? Unless specifically indicated by the manufacturer, one cannot usually swap transducers among instruments, if one does/did do so, well indeed the transducer maybe damaged and or the output of the sounder maybe damaged as well?
These manufacturers actually make it so that none of their equipment is interchangeable, as they wish to maximize the profits you see, and if one could just swap things among models etc, then "They" would, in their mind anyway "loose out"
So you will simply have to cut a new hole and mount for you new transducer. make sure you mount it in the manufacturers recommended place, the Bow is fine, although I often recommend that it be central to the craft, but, sometimes this isn't possible for varying reasons.
Sometimes if one must retro-fit a new transducer to an existing but different size etc site, then, it is best to "Fill" the old mounting hole(s) with a suitable material, and then re-drill and re-mount it all again.
