Question about Mitsubishi Televison & Video
How do I fix the air vent on my 73' Mitsubishi t.v.??
How to fix a 73 in mitsubishi tv that was struck by lightning?
You will need to take this to a repair center. Expect it to be un-repairable.
Aug 03, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
How to clean mirror and optics mitsubishi 73 dlp
You have to remove the lower panel on the back of your tv, then remove the light engine. Unhook the wires attached to the DMD board. Remove the DMD board. Remove the heat cink from the DMD board. remove the optical lens but don't touch the lens. There is a video on shopjimmy.com that shows the entire procedure. Takes 2 hours. The optical lens can be cleaned with an eyeglass cloth, same for the DLP chip lens. no wet solutions on lenses. Remove dust from other internal parts with compressed air in a can. Your picture will be clean and clear. Wear latex gloves and make sure you are grounded to prevent static electricity.
Feb 23, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Heat TEMP and blower problem.
Your blend doors are not working properly. There is small electric motors that move them. Shouldn't be really expensive to have fixed.
Jun 01, 2017 | 2000 Chrysler LHS
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
72 in shuts off 3x every 10 min.new bulb 7 th one mitsubishi 72 in
You need to check on the power supply board for Bad Capacitors they will be vented,swollen, or puffed up on Top. 680uf 10v,330uf 10v 3300uf 10v 2200uf 10v,
Sep 01, 2010 | Mitsubishi WD-73927 73" HDTV
I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
My tv turns blue and turns itself off
optical block assembly going bad. repair is pretty costly. try vacuming out the fans. DO NOT USE CANNED AIR!!!! you will blow all the crud into the optical block.
Jul 12, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Message on screen says tv will shut down ck air vents for blocks
you must have a wd series mitsubishi..the lamp tempurature sensor has a manufacturing problem..mitsubishi has an updated one to take care of the problem..the sensor itself is not bad it is the way the wires are crimped in the plug,,the new one is soldered..the part number is 299P313010A,
Sep 17, 2007 | Mitsubishi WD73727 73" HDTV
Televison & Video Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
