I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Testimonial: "not the answer i was looking for.. and i checked the manuals and the torque ratings either were not there or translating the numbers i have dont match theirs.. and ive also googled it and i get answers like 189 or 140 ft lbs and that will snap a head bolt or crack the aluminum head in a flat second.."
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
SOURCE: Cylinder head bolt torque setting for a
Search Briggs on the Web, You can order Manuals there. The torque is in in. pounds. Need more info ! A just get them tight and all about the same will work, stagger the bolts in the Head when tightening ( one bolt, one side then the other until done.) Then check them all.
The decompressor is a valve lifter usually on the exhaust valve, the only adjustment is to correctly set the the valve clearances, if they are too slack the lifter will not activate.
SOURCE: looking to know what torque level lbs. to use on engine bolts after replacing head gasket
Try SearsPartsDirectcom they will help you.
