Cleaned carburetor no help
It is quite unusual for them to exude fuel from the carb, if somebody has removed the carb at some time it is possible they have re connected the fuel hoses incorrectly, it is important to remember that the fuel bubble is a purge not a primer, so it pulls full from the carb into the bulb and back to tank, if the hoses are incorrectly assembled you can push fuel into the carb, this would cause fuel to exude from the carb.
SOURCE: I need to rebuild the carburetor on a Stihl model
I don't have a diagram or the part numbers to the minor and major repair kits, but a Stihl dealer should be able to help. Tell him you need a kit for a ZAMA C1Q type carb. The exploded view should be with the kit.
SOURCE: I have a Stihl chain saw an O8S. The carburetor
I would try here first. I have had good luck getting old parts here. I hope it helps you out.
www.jackssmallengines.com/stihl_index.cfm
SOURCE: i have a Murray hydrostatic
If the plug is dry than you have some sort of blockage still in your carb you need to go in and really clean all the little orifice's and screen if it has one. Dry plug, no fuel, carb clogged simple small engine dynamics.. Good Luck! Don't forget the thumbs..
SOURCE: my poulan chainsaw will start
One thing you might check is the vent on the gas cap to make sure it is not plugged. I have had them plug tight and not allow fuel to be draw on accelleration. Hope this helps you. Thank you.
SOURCE: Stihl MS 290 won't fire even when primed directly into cylinder
crank seals are probably shot :-(
