SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
[email protected]
www.coachtech.info
734 777 6432
SOURCE: Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
SOURCE: our rv has a dometic rm2600 fridge that smells of
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
