SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
SOURCE: Timex Indiglo T436B alarm clock
my timex t436b's radio stoped working on f.m. but a.m., audo in works the sounds work so if you have any clue how to fix it please tell me
SOURCE: Turn Off alarm on T235 Timex Dual alarm clock
To disable the alarm, make sure that the radio is off. Then press the appropriate alarm button (ALM 1 or ALM 2 on the top of the clock at the right of the line of multiple buttons) repeatedly until neither the Buzzer or Radio indicators for that alarm are lit.
This is given in the manual on page 8. However, the detail about making sure that the radio is off is only in the sections about setting the alarm (page 4 and 6). The manual is available here: https://timexaudio.com/T235B/ . The direct link to the manual is currently https://timexaudio.com/media/uploads/product/files/T235_User_Manual.pdf . Note: the PDF is only one page; the page numbers are for small sections of the page in the mini-format manual that ships with the clock.
I hope this helps.
