Question about Nordic Track Exercise & Fitness
Nordic track c3si model # 831.21873.0 keeps beeping. during workout and after. does not register when you push buttons.. . usually Sorry for lack of model the first time!
6ya staff
SOURCE:
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Posted on Jun 14, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: nordic track console seems frozen
Since I don't know the model # I will take a wild guess and say they maybe batteries in the upper console that need to be replace or if it has a power supply in maybe the upper console that has failed. Get back to me if I'm off the mark thanks!!
Posted on Jun 29, 2010
spamslisher
  • 3 Answers
SOURCE: C2155 treadmill 1 1/2 yrs old, Nordic track. Panel
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Posted on Oct 31, 2010
Steven Buford
  • 3 Answers
SOURCE: i have a nordic track
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Posted on Oct 29, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Posted on Nov 08, 2011
I have an exp 1000 and during a workout the belt stopped and the machine started to beep and motor is hot. Can this be fixed?
Most likely you need to replace the motor and MCB. I might have these parts in my shop. Also check to see if the front and rear rollers are moving freely by disconnecting the drive belt. Shoot me a email at Elitefitnessrepair@gmail.com for parts
Apr 07, 2015 | Nordic Track Exercise & Fitness
Stops dead during workout
Dear Sir:
Most of the problem with this situation is lack of lubrication and regular maintenance.
The treadmill is very complex electronic equipment. The friction between deck vs walk belt is Enough for to protect the equipment, the electronic design shut down the treadmill, for to avoid damage to the electronic components.
2nd failure is main motor board. But you must lubricate your equipment, see your instruction manual or user guide. If you do not have you can download free from Nordic: www.Nordic.com, go to service customer, then parts%Manuals, give your model, etc, and download for free.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Feb 14, 2012 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic track commercial 1300 manual
Jun 12, 2010 | Nordic Track Exercise & Fitness
What do the distance numbers represent on the nordic track elite 1300
If no distance goal was set, this display will show the distance that you have pedaled, in total revolutions. If a distance goal was set, the display will show the distance still to be pedaled during your workout.
May 09, 2010 | Nordic Track NordicTrack Elite zi...
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Aug 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
76 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
