There is one hinge but two pivot points. One near the door itself and the other inside the unit where the hinge rotates into the machine. The inside pivot is directly below the detergent dispenser. If you use too much detergent or you put liquid detergent into the unit not using the liquid 'cup', then some of the detergent splashes down the inside of the washer and land on the hinge pivot. Then slowly over time, the pivot 'rusts' and stops pivoting well, holding the side of the door ajar even though the door locks. Water can then splash out. Sometimes 'liquid wrench' or WD40 can loosen it. Sometimes not. Take top off, take control panel off, take front off, to get to hinges. Hardest part is putting spring sealer back on door boot. Watch a few videos. Good luck.
Yes, you need to get the hinges or door replaced.
If your getting water coming out. Your pump is not working or is clogged with a coin check the hose. And have a shop vac ready to suck up the water. The door has a lock and should not open on front loaders till the cycle is complete and water is drained
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
SOURCE: LG front load washer -- water leaks
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
SOURCE: LG makes a high pitched sound during water add cycle
Hello.
The high pitched sound is a definite sign that the water valve in use is failing. The squeal is from a restricted water flow through the valve because it is not opening all the way. You will need to choose cold or hot to narrow down which valve is bad and replace that one.
SOURCE: how do you drain the drain pump in lg front load
There is a small panel on the bottom left front of the washer with a tab on the top middle holding it onto the front of the washer. depress this tab with a small flathead screwdriver and the panel will open downward. You will now see a small round black piece on the left with a flat screw head on it, about an inch in diameter. unscrew this about a quarter of a turn and it will come out with a small hose attached. This is connected to the drain pump. Have a shop vac ready, pull the black plug out of the hose and this will drain the pump. The larger round piece on the right, about 3 inches in diameter is your drain pump. After draining all the water unscrew it with your hand. When you get this out it will have a screen attached which needs to be cleaned at least once a year.
Please rate this post. Thank You.
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
