My set has got a tinted blue screen I have tried going into settings and tried to reset the back light settings but it is greyed out and it wont let me. The tv is all working apart from this blue tint on the screen. I have been told it could be the board in the back of my set,If i was to replace this will this sort out the blue screen and will it let me use the the back light settings on the tv. Many thanks. Noel.
Hey Noel, that is just a T-com board problem. Replace the T-com board.
Testimonial: "Hi B1jqxk44. Thanks for getting back to me on this matter. I have been told to change the t-com board the main board plus the led lights.The T-com board sounds the best advice you have given.I know nothing about tvs So witch one is the T-com board is that the one that does not have the mains cable running to it. Many thanks. noel."
The T-com board is the one that has one ribbon from the main TV board going to it. And two ribbons coming out going too the TV screen. Most TV's t-com boards are in the middle at the bottom of the TV. And some have a protective plate over them. Be careful not to damage the ribbons when removing them. Lift up the clip with your finger nail and slide out the ribbon.
Thank you for that info.
Could there be a chance its the LCD Inverter Board?,I have had so many people telling me what it could be i just dont want to be spending to much on this set.
I have been told main board, lcd board, screen,and has you have said the t-com board.
I have just had a look in the set and it is were you say it is but this one does not have the plate over it.
Again many thanks on all the help on this matter i will now order the new T-com board.
Thanks.
Noel.
There is no chance it the LCD inverter, because your TV is a LED. LED and LCD are two different types of TV's The back lighting is different. LED are stripes with small lights. LCD are floresent tubes. Go to Shopjimmy.com for the T-com board they have good prices.
Again many thanks for all your help on this.
I will go to the link you sent me to get the part you said i need,I will let you know how i get on when ever i put the part in my tv.
Many thanks.
Noel.
When you order the new T-com board, make sure you order the part number on the paper sticker on the old T-com board. not the other numbers on the board.
Ok thanks for that info.
I made that mistake a couple of times. Even though the boards looked identical, they are different. For example, I have three Samsung power boards, that look identical for a 42" 46" and 52" That's why that paper sticker number is important.
Take care and keep in touch.
If you have problems with the t-com board email me at: [email protected]
ok thanks.you take care and i will let you know how i get on.
ii earned $5000 last month by the use of operating on-line most effective for five to eight hours on my pc and this was so clean that i in my opinion could not accept as authentic with earlier than running in this website. if you too want to earn this type of huge coins then come and be a part of us. do this internet-website on line ...........gÂÂÂo tÂÂÂo tÂÂÂhiÂÂÂs siÂÂÂte hoÂÂÂme media tech tÂÂÂaÂÂÂb fÂÂÂor mÂÂÂorÂÂÂe dÂÂÂetÂÂÂaÂÂÂiÂÂÂl thank you . copy&paste:) HERE?...... ... www.green.jobs67.com
SOURCE: Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
SOURCE: Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
SOURCE: Sony KDF60-WF655 Picture has a blue tint
Sony has decided to cover this cost even without warranty.
SOURCE: Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
SOURCE: Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
