SOURCE: Fujitsu wall mounted air conditioner leaks into the room
Make sure the unit is level, this is very important. Check for blocked drain tube, which runs from the bottom of the drain pan under the cold coil to the outside. Clear tube with a piece of coathanger wire, be gentle.
SOURCE: Old Ruud Air Conditioner
all heat pumps follow the same schematics universal get a hold of any heat pump schem and you should be able to aplie it to yours
SOURCE: kenmore window air conditioner model
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
SOURCE: Instruction Manual need for a
the compressor is not running and .near to the service unit their is a board and in it three leds ware their .when the out door is started that leds are blinking and compressor is stop and the fan is working for a at least 30 so what do u think the problem is.
