SOURCE: need instruction manual for shark euro pro s3325 floor cleaner
try this link
http://dl.owneriq.net/7/7d4a831f-23ee-5b94-4d27-46523a0b7fa0.pdf
tnx 4 using fixya,
drcool
SOURCE: The belt broke on my my SHARK Model V15Z and Euro
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
SOURCE: i need a user manual for the shark euro pro s3101
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;j
SOURCE: i cannot find manual for
go to.... http://dl.owneriq.net/6/6639ab83-34ea-0a44-d571-45fe5b5a50d3.pdf it is the instruction manual
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
