Amana AOCS3040 Electric Single Oven Logo
Posted on Dec 11, 2007
Amana Convection oven not controlling temp
Amana Convection oven Model NO. AOCS304055
It has 3 elements: broil, bake, convection, the bake element is "hidden".
Problem, on normal bake, the oven will not maintain temperature (60 degrees low). It preheats fine but then the temperature drops.
What I know:
-Convection Cooking cycle works fine and controls temperature properly.
-The coil resistance of the bottem baking element is fine (28ohms)
-Power is getting to the coil (measured at the coil terminals)
-During preheat the coil is energized about 25% (15 sec on 45 off)
-During bake, the coil is only energized only about 4 seconds every 60 sec,
even though the temperature is well below the set-point.
-Trying a clean cycle, the motorized door lock latched, but after the cycle
was canceled, it was stuck latched for more than a day, even after cycling
power, we repeatedly got the F9 error. It took a deliberate "reset" to clear
it. Not sure if this is related.
Trouble shooting Done:
Relay board replaced
Calibrated temperature & within 10 degrees of setpoint in convection mode
Verified power to bottom coil
Verified coil resistance
Assumptions:
The thermocouple & controller are fine because convection mode works
properly.
The bottom coil is fine because it heats properly in preheat, and has normal
resistance.
Questions:
Should the convection coil turn on during normal bake (it doesn't), or bake
preheat?
Why would the controller not turn on the bottom element more if the temp is well below the setpoint?
Any troubleshooting ideas?
  • Anonymous Dec 26, 2007
    We are having a similar problem..Preheat seems to be OK. A thermometer placed in oven showed temperature where it was set. However, baking times seem way long, which would agree with the temperature drifting 50-60 degrees low. We have had a repairman out twice under warranty and still have the problem.
  • Anonymous Dec 30, 2007
    I have the same problem when baking. I am tired of trying to figure it out, I have opted to just allow more time to bake. Per the manual, during Bake the top and bottom elements should operate, during Broil only the top element operates, and during Convection the upper element, lower element and fan should operate.
    I also have another problem and I don't know what to do about it. Maybe you have some suggestions. The tempered glass FRONT panel on my oven broke and since the company is not longer manufacturing these ovens, it cannot be replaced. I ordered if from a replacement parts website, only to be told they cannot get it anywhere. The oven still works without the glass panel, but as you can imagine, my kitchen looks horrilbe without it. A new oven costs about $1,200, but I don't think it is fair that I have to buy an entire new oven because of a part that is not replacable. Linda
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Dec 30, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4457
Points
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Whirlpool YWFE710H0BS0 oven no longer heats up.
Check the elements for continuity with a multimeter. Sometimes the connectors draw too much current and can burn out as well. Both are easy tests. A runaway temperature can make elements fail because there is no thermostatic control, they just glow bright yellow..
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 • Ovens
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 • Amana Ovens
1helpful
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 • Dacor Ovens
2helpful
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
1helpful
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Top Amana Ovens Experts
ADMIN Andrew
ADMIN Andrew
Are you an Amana Oven Expert? Answer questions, earn points and help others
