Hi Chakuma, indicate your Panasonic radio model that you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Chakuma, indica modelo de tu radio Panasonic que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: Panasonic EH65 HDD/DVD
Dis connect from the mains- wait a while then re connect what happens?
SOURCE: picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
SOURCE: acer 6920 blue ray problems
I have had the same poblems after buying my lap top from Currys. I emailed acer and all they would say is that all of the warranties have been taken over buy PC WORLD who are the same company. They then said that i should contact the tech guys. The tech guys tell you to restore to factory settings which tales off anything that you have already put on the computer. I then contacted the software tech guys £1.50 a minute line and the bloke i spoke to said that it was the fourth call that he had recieved that morning and the advice that he gave me was to return the computer as it was less than a month old and state that it was not fit for purpose. I took the lap top back to Currys and explained what i had been told to do. In the end they installed Power DVD 8 on my computer which allows me to play all blu rays on the computer. However i still can't connect the acer up to my HD eady tv without it freezing. It appears that the software supplied is absolutely **** but acer are happy to let you get on with it. The only real solution is to obtain third party software and update your graphics drivers. In time hopefully acer will release better edition of the pre installed software.
It is a real shame as the laptop is great apart from this blu ray issue which seems to be a well known problem as it is mentioned on many forums.
I hope this assists
SOURCE: DVDs freeze every few seconds while playing
this could be from a number of issues. first is it a home made disk? second the type of changer you are using?
home made disks can be fixed by using a + or - disk depending on the disk and what the drive likes.
as for the second issue it could be a cooling issue or the lens might be dirty try blowing it out with some can air and try to use a lens cleaner disk. they should be able to sell one for about $5 - $10
SOURCE: Acer 5738g freeze playing CS and Warcraft
Hi there.
I too had this problem.
After checking a few things i decided to sent it in
for warranty. Acer replaced the motherboard as they discovered
a north bridge failure.
