Dryers Logo
Posted on Sep 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire dryer AEQ7000EGO not heating up
Dryer is not heating up. Tumbles but no hot air
Anonymous
Level 2:
  • Expert 110 Answers
  • Posted on Sep 13, 2009
Anonymous
Expert
Level 2:
Answers
110
Questions
Helped
27186
Points
249
You need to make sure you are getting 220, your dryer will run on 120 but not heat.
2nd check fuse that is located inside dryer near drum
3rd check heat elements for breaks.
Frigidaire aeq7000ego dryer will not heat and shuts down before cycle complete...what could it be?
don't know about cycle - not enough info - but usually when dryer does not heat the heating element needs replacing.
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Where is fuse on frigidaire aeq7000ego
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Turns on & tumbles but no heat. top got really hot b4 it quit drying
You may have a clogged vent.your machine gets to hot and safety switch kicks in or you lost the blower fan
when drying does it sound like air is blowing.... let it cool down and see if it starts again
The dryer is a frigidaire model aeq7000ego and it doesnt put out any heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
1helpful
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
1helpful
Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
20helpful
4answers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
