Most Mitsubishi sets use the same basic code for the last 25 years for on/off etc--the only difference is features like pip etc.
try either by numbers if you have them or a code search for the set with it off, when you find the correct code the set will come on. If using a universal don't expect it to do everything the original remote did.
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12/09 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
You can access the menus using the buttons on the set. Go to audio menu, you'll find a setting that says listen to and have choices of mono stereo or sap, choose stereo.
turn off the sap in the audio menu. sap is "secondary audio programming" i believe, and sometimes stations will broadcast in spanish on this sap or will broadcast weather or emergency information. these channels are probably broadcasting a mute sound over the air.
YOU ARE IN SAP MODE. IF THERE IS NO SECOND AUDIO PROGRAM ON THE STATION YOU ARE WATCHING YOU WILL GET NO AUDIO. SWITCH SAP TO STEREO OR MONO. SOME REMOTES HAVE A MTS BUTTON ON THEM.
