Screen went bright blue then black . Older model 1998 52" Rear projection tv. Was working fine, no issues all of a sudden big light in the middle. Now when you turn it on, it is blue then black with no picture. Is it worth repairing? No money for new TV right now!
Hmmmm! I would have to say you have a problem with the signal board. I have not repaired this brand or model. This would be the first thing to investigate. It is the board that contains all your antenna and rca jacks. Good Luck and visit your TV tech with this info!
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Hello, You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun. If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further. thank you.
