Cameras Logo
b
bob van lindt Posted on Jul 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My canon 30D flashes (err cf) repeatedly even after following instruction re: turning off & camera and changing battery -advise
pgtroncoso
Level 1:
Habit-Forming:
New Friend:
  • Contributor 33 Answers
  • Posted on Aug 10, 2019
pgtroncoso
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
33
Questions
Helped
6947
Points
74
Try a different card.
matt
Level 3:
  • Canon Master 1,666 Answers
  • Posted on Aug 03, 2019
matt
Canon Master
Level 3:
Answers
1666
Questions
Helped
696238
Points
9998
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Jan 16, 2008
SOURCE: Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Q4SteveB
  • 159 Answers
  • Posted on Apr 03, 2008
SOURCE: Canon EOS 30D SLR Will Not Turn On...
I seem to recall hearing that the power switch can be a problem on the 30D .. I'm not going to suggest you take it apart to clean the contacts .. better go to a Canon Dealer I think ..
Jarrett
  • 51 Answers
  • Posted on Jan 30, 2009
SOURCE: err 99 & err cF in my canon 350d camera
had the same problem before
found this guide online
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Jarrett
  • 51 Answers
SOURCE: Error 99 on 30D Canon
Had this problem before and i found this guide online
camera body.
t00nz
CameraR
  • 4738 Answers
  • Posted on Jul 02, 2009
SOURCE: CANON REBEL XT -CF card error
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, you may elect professional repair (likely more than you'd be willing to pay), or you might want to try the following.
Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Error 99 is my problem... any ideas on a fix?
This may help you, it is from Canon.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most
camera body.
If the "ERR 99" message only appears when one particular lens is
If you see the "ERR 99" with a different Canon lens attached, then the
For factory service, forward your digital camera (remove the CF card
and battery) properly packaged and insured, with a letter describing the
difficulties. Be sure to include your name, address, telephone number,
and proof of warranty (if applicable). Send to the Canon Factory
Service Center at the following address:
Canon Factory Service Center
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
Tel.# (949) 753-4200
Your equipment will be examined and you will be advised of the
findings.
The length of time for the repair will be dependent upon the nature of
the repair and availability of parts if needed. If the repair entails
something that is not covered in warranty you will be sent a written
estimate to the address that you have provided.
Thank you for choosing Canon.
Sincerely,
xxxx
Product Support Representative
3helpful
Err 99 appears after every click for canon eos 30 D
Err 99, but lens-to-body problems are common- thought error 99 is a bit of a catch all- generally a lens and body conflict. And also Err 99 means that something wrong happened, but then it cleared out before it could be further determined.
Here is the blurb from canon to try:
your EOS 10D is displaying an "ERR 99" message.
following:
steps:
camera body.
100 Jamesburg Road
Jamesburg, NJ 08831
Tel.# (732)521-7007
or
15955 Alton Parkway
Irvine, CA 92618
findings.
Please leave for me, a rating...
6helpful
2answers
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
2helpful
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Err 99 & err cF in my canon 350d camera
camera body.
1helpful
Canon EOS30D: Overexposure in Auto Mode
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
camera body.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 • Cameras
1helpful
2answers
camera body.
2helpful
3answers
I have error 99 in my camera canon 400d
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Error code 22
ERR 22: CF DRIVER
DESCRIPTION: This error occurs when image data cannot be written to the CF card. This error can occur when the CF card is not fully seated in the camera or if the D30 does not detect a card-ready signal within a specified time limit or when the CF card is not usable because it has been corrupted or physically damaged. It can also occur when the camera's battery level is insufficient to completely write the file to the CF card. REMEDIAL MEASURE: Use the DC Coupler or recharge the battery first. If the error continues to occur with sufficient power available to the camera, check that the CF card is properly inserted. If that's not the problem, then try replacing the CF card. If that does not solve the problem, have the EOS D30 and one of the CF cards that is causing the problem examined by a qualified service technician.
Got this from here: Digital Outback Photo
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
