Unlocking a Nokia E63 requires an unlock code to remove the SIM lock. By default a SIM lock comes on the E63, which prevents it from being used by other phone carriers. You can usually get a free unlock code by requesting one from your phone carrier. Once you have the unlock code you can use the free Nokia E63 unlock instructions here to unlock your phone. Good luck!
To unlock your Nokia phone you will need to enter the code. This code is
just a calculation of IMEI number of your phone. To find your phones
IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number. I can recommend this one (cheap and reliable).
Click here to unlock your Nokia E63.
Note: don't share your IMEI number on free forums like this.
How to unlock iphone 5
SOURCE: I need unlock code for nokia e63
Friend you can get the unlocking code from http://www.mobile-unlocker.com/ .It provides the unlocking service for your mobile..
SOURCE: unlock code for nokia e63
hai, U get the unlocking code from http://www.mobileunlocksolutions.com/. Because it provides the unlocking service.And it's also having the unlocking code for your mobile.
SOURCE: unlock code for nokia E63
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope it helps
SOURCE: nokia e63 unlock
Unlocking a Nokai E63 SIM phone requires an unlock code which you can usually get for free by calling up your phone carrier and requesting one. In exchange they will want your IMEI number which you can get by typing *#06#. Then you can use these Nokia E63 Unlock Instructions to remove your phones SIM lock to use it with any carrier you want! Good luck and i hope this helps!
SOURCE: unlock nokia e63 vodafone australia
http://www.unlock-nokia.com/
Please find your unlocking link above.
http://cgi.ebay.com.sg/Unlock-Code-Vodafone-Australia-Nokia-E63-E71-E72-/170459562506
http://www.unlockallcellular.com/nokia-unlock-code-np-4714.html#instructions
These two links above show you how to do it, the last one is frree
