Hi--
just confirming these are the correct caps showing up to replace?
EF6225-ND 2.2UF/630VDC METAL POLY CAP
E6105-ND 1.0UF/630VDC METAL POLY CAP
thx!
Fixed problem by replacing capaciters via lwin62 advice thanks.tv works good as new.
Fixed problem by replacing capaciters on power board via the post by lwin62 thanks.to think that the tv shop was going to take me for aride for 1000 bucks .
Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went.
I have same symtoms with same plasma i had a tv repair man look at it and said it would cost me 800.00 +labor.He said one of my boards need to be replaced.So a year later i am trying to get this tv running myself i just orderd the compacitors and take a long shot at relacing and see what happens I'm good at solder and following scem.if i had one for this pdp42bk.the compacitors im replacing are the1uf 630v and2uf 630v in power board.I also noticed the can capacitors are alittle warped on top .can anyone add to this problem or descriptions.my symtoms oo tv was it turned off by itsself and would not turn back on the green light turns on then clicks goes right to red no pic nothing.
http://rolsen.ru/content/tech/POWER_Sche...
This is the link for the schem. But all you have to do is change those three caps I listed above and you should be good to go. To those who got their tv's working I am glad to know I could help.
