I have a kenmore front loader washer model 41741042000. It will not drain or refill. It runs through all the cycles with the same water in it but it never goes into the spin cycle.
All front loading washers will fill and drain multiple times before it finishes. Unlike a top loader, a front loading washer will take longer to run because there is no agitator and will fill with water and drain multiple times. A front loader is more energy efficient than a Traditional top loading washing machine. A washer dryer combo will take hours to complete a cycle.
check for a kink drain hose are you have lint clog up in you pump ,you have to take the lower front panel off to see the pump depend on your model.you may have the pump in back of your washer.
The filter on your pump is probably clogged with lint and
stuff. You have to remove the bottom front panel, 3 torx screws
underneath. The
panel will drop and come off. Drain off the excess water from the hose
you
see.The white filter cover is right in front.
Get yourself a bunch of towels or a good big plastic bag to collect
water.
Unscrew the filter cover and twist the filter out. Clean out all the
stuff and
put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits
of soap and other such things can be
stuck around the inside tub of your washer. Try this product, it works
great on
all front loaders. Use quite hot water with the Affresh pellet with no clothes
and
run the machine through a cycle.Also
helps with any stagnant water smells. Have you cleaned out your pump
lately.Put the pellet inside the
machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
