My Stoves 720EF Heritage oven keeps turning itself off, I reset the clock but it keeps intermittently turning off, sometimes when resetting the clock it resets back to 0.00 on the display and won't let me reset it. Help!!
You obviously have a power loss somewhere. The oven will not work unless a time is set on the clock. I would suggest you have problem with the feed to the cooker which an electician should be able to check it out. If anything else is wrong on the cooker, it shouldn't reset the clock.
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
I have just uploaded a scanned copy of the stoves 720- EF manual to the link below.
Requires the free Adobe Acrobat Reader or similar software to view the manual which most computers already have. The stoves ef720 manual file below is full and free of charge
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
