The only way possible to see if the touch
pads are working is to test the voltage of the control pads when it contacts.
The input of the Microprocessor should be checked for the pad control impulse
to come in. If there is no trigger voltage to the mP this can be the control
pad problem.
The mP must be checked for the working voltage and also the frequency
oscillation at the crystal leads. If so the mP is working with a suspected
control pads which are not able to set the program or timing.
There is no way but to remove the sticker pad and replace, One difficult way to
have a chance is to remove the carbon sticker pads and check continuity , You
can use a carbon pen to line the tracks so that the multi-meter reads a
continuity. With this you can have a temporary fix
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™
Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM
pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5
speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9
Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6
codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto
& Time
Delay Start: Yes
Display On/Off: sub-pad
w/ zero
Express Cook: Instant-on
1-6
Reminder (24 hr): Yes
Time Cook: I
& II
Time Preference: Control
Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire
Oven Rack
Sound Volume Control: 4
levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless
Steel
Door Color: Black/Stainless
Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63
lb
Overall Depth: 15
5/8"
Overall Height: 16
3/16"
Overall Width: 29
7/8"
Cavity (W x H x D): 20
31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
Is it louder or quieter than usual? What is your brand & full model number? We're happy to help you with free advice. NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help. William E. Miller [email protected]http://www.microwavedisplay.com
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly. ------------------------------------------------------------------------------------------------------------------------------------------- Let me know the brand and full model number, whether the internal cooling fan is coming on when you try to microwave, and if the oven is louder or quieyter than usual. ------------------------------------------------------------------------------------------------------------------------------------------- William E. Miller [email protected]http://www.microwavedisplay.com
